‎2022-04-08 01:27 PM - edited ‎2022-04-08 01:33 PM
Hello, I'm trying to create a simple cube (to evaluate how flexible param-o is) with only two size options, 1m and 2m but I cannot find a way to do it, if any.
Solved! Go to Solution.
‎2022-04-08 06:11 PM
Try this
Hope this is what you expecting.
I have attached one zip file which you can extract and use in Archicad.
Try this
‎2022-04-11 09:12 AM
Thank you for the suggestion it works as intended.
