Parametric design
About Rhino & Grasshopper and PARAM-O.
Skylight
I've realised that we can't import skylight from ArchiCAD to Grasshopper. Is this element will be implanted later on?
How could we do now to import skylight into Grasshopper? Does someone find a way?
Best,
Frank
Just to update my previous question. That will be really usefull to be able to import skylight.
Thanks in advance for your answer.
Frank
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Frank,
Thank you for the question and I am sorry for the issue!
Unfortunately, the native Skylight tool from Archicad is not yet available as separate component in Grasshopper. I entered it as a wish in our Wish List database (please refer to it as #12871). Hopefully our Product Management team will consider implementing it in the future!
Thank you for your understanding, and I am very sorry for the inconvenience!
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Minh,
Thanks for your answer!
Look forward to it then
Best regards,
Frank
