rubymoon
Text transfer from grasshopper to archicad
Hi I need help knowing what script component to use to transfer text tags or 3d text tags into archicad using grasshopper archicad connection. have anyone tried this before?
1 Reply 1
runxel
Depends on what you actually mean.
Actual text (there is "text object" and "text block", not to be confused with one another; one is editable, the other makes lines and curves) is a thing in Rhino, but not in Archicad. You would need to use the "3D Text" object from the library for that.
And then there is the "dot" (seen on the cube, sometimes referred to as a point tag) – they have no equivalent in Archicad at all.
