Transformation of Object using Grasshopper(Move/Rotation)
Hi All,
I have rhino block. Using GDL I created copy of archicad .gsm object similar to rhino block. Now I wish to place this object to various locations in Archicad, There are many instances of this object therefore I wish automate this process somehow so that I don't need to place each object to its location manually. I can read transformation information(move vector and rotation angle) of the block in rhino. So my question: Is there any way to place these objects on desired in Archicad using Grasshopper.
Ps. I am new to archicad. Later, i want to edit this object in archicad(make it detailed) so that all instances of that object will reflect the change.
Any help is appreciated.
Thanks!
2 Replies 2
runxel
Short version:
Yes, you can do that.
With what exactly do you struggle?
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
It is possible to do. Download the ARCHICAD-Grasshopper User Guide and search for the "The Object Settings Component" section.
There you will see that the "Object Settings" Component has an "Angle" Input. Then the Output of this "Object Settings" Component goes into the "Object Settings" Input of the "Object" Component, which places the Object element type.
