Hi All,
I have rhino block. Using GDL I created copy of archicad .gsm object similar to rhino block. Now I wish to place this object to various locations in Archicad, There are many instances of this object therefore I wish automate this process somehow so that I don't need to place each object to its location manually. I can read transformation information(move vector and rotation angle) of the block in rhino. So my question: Is there any way to place these objects on desired in Archicad using Grasshopper.
Ps. I am new to archicad. Later, i want to edit this object in archicad(make it detailed) so that all instances of that object will reflect the change.
Any help is appreciated.
Thanks!
