Parametric design
About Rhino & Grasshopper and PARAM-O.
continious crashes
Ahmed_K
Mentor
Hi mates , i'm using the Archicad GH connection since 1 month, every day i encounter several crashes when i try to exchange data between GH and Archicad, ( when working on GH only all is fine)
I have all archicad updates installed and latest GH connection , same problem with Rhino 5 and 6
Any help please ?
Archicad 27
Windows 11 professional
13 REPLIES 13
felcunha
It happened with me until I reduce the screen resolution to 1920x1080. I suggest you try it if your screen resolution is higher.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Ahmed_K
Mentor
Helle ! thanks for the reply
it crashes on 1920/1080 screen resoution and lower
Archicad 27
felcunha
Did you try to uninstall and reinstall your AC-GH connection ?
Ahmed_K
Mentor
i tried, still crashes sometimes
Archicad 27
Ahmed_K
Mentor
Any help please ??
Archicad 27
Which build of 22 are you using? I had the same issue when running on 4023 - I think 5003 fixes it.
Ahmed_K
Mentor
I'm using Build 5009 ( frensh) , Rhino 6.11 with grasshopper included ( some plugins are installed like weaverbird, panneling ools, lunchbox )
Archicad 27
felcunha
Try to deactivate the other plugins, restart your computer and see what happens. I've have an info from a plugin editor who told me there could have a conflict between his plugin and AC-GH.
Daniel Kovacs
Graphisoft Alumni
Hello bouhmidage,
Has this issue been resolved? Do you still need help?
If it was solved, what was the solution?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
