‎2008-08-22
02:19 AM
‎2023-05-30
01:12 PM
Rubia Torres
‎2008-08-22 03:17 AM
JMM4JMC wrote:have you actually tried opening your 11 template file with 12 and then re-saving? that should do the trick
Is there a way to transfer all or most of my favorites settings that were based off of V11 library to V12 library? It would be quite time consuming to save new favorites in V12.
And or saving a previous template made in V11 to V12 with the V12 library etc?
And I guess the same with layers, line types, fills etc.?
‎2008-08-22 03:27 AM
‎2008-08-22 03:45 AM
‎2008-08-22 02:17 PM
‎2008-08-22 03:56 PM
Lennox wrote:That is what I'm trying to avoid, defeats the purpose of using the newest library/parts. Every new version, I have to redo some my favorites in one form or another, I guess I will have to keep doing it.
I suppose you could load the AC11 library, that way you have less work to do. Im about to tackle the same job some of my library parts go back to V9!
‎2008-08-23 07:27 PM
‎2008-08-23 08:13 PM
Bier wrote:The ACE library is a great volunteer effort to unify libraries - something that GS themselves should have done. But, that lib is still at version 11 AFAIK ... and using it has nothing to do with getting old Favorites to work with new library part functionality. Replacing Favorites for any object-type tools is a slow, manual process that even parameter transfer cannot solve because of the types of changes that have been made.
For the North American market, this may be the way to go as
base library?
http://www.archicad.ca/?p=75
‎2008-08-24 12:12 AM
‎2008-08-26 01:44 AM
