2015-06-02 10:03 PM
2016-06-15 08:36 PM
2016-06-15 11:13 PM
Richard wrote:I agree. The first thing I always carry across to the person I explain BIM in general and ARCHICAD (or, God forbid — Revit) in particular is that
now, for example, I have a choice of 4 possible layers, rather than over 30 in the previous template for that layer combination alone.
Richard wrote:Naturally, you will need to save it at some point if you want a stable Saved View, but, again, don't do that before you need it.
turn on/off whatever couple of additional layers I might need, and live with the layer combination name "custom." Not a big compromise.
2016-06-17 08:35 AM
1. They can be turned on or off to hide/show content.So what about filtering by extension, using layers for scheduling criteria and fields, including layers as Find & Select criteria, assigning layer combinations to views, using layers for mapping during export to other applications, using layers to reserve elements in teamwork, mark-ups, label association, the list goes on. Layers are important. Maybe for more than what each individual user may require but we're trying to show off all of ARCHICAD's amazing capabilities here.
2. They can be locked to prevent accidental editing (although, Holtinked Modules work better in preventing accidental editing, and, if you use Teamwork, they also provide much more secure access control)
3. Allow for intersection control among structural elements
4. Can be turned into wireframe in 3D to make complex 3D views easier to read
Alternatively, one can buy some predefined template he/she did not set up and do not really understand, pay 100, 200 or even 500 dollars for them and the only result would be that you spend 5 hours deleting all 500 linked views in the most expensive template, 2 hours in the one for 200 and about an hour in the one for 100. What is the point?
So, templates, especially extended ones (some of which are even commercially marketed for upward $500) will take an enormous time to clean up, move every preset elevation, section, publisher set etc. Just imagine editing some 400+ items every time you start a new job. Do you have better thing so to?I believe our template system is as flexible as an ARCHICAD template is able to be. It's just a fact that ARCHICAD templates can only be so flexible (hence the original topic of this thread), but we intentionally provide a bit too much so that it can be quickly stripped down, and we provide instructions on how to do that. A subtractive methodology is easily better than an additive one IMHO. If you're taking 5 hours to delete the views and then you're doing that every time you start a new project, then you're doing it wrong.
2016-06-18 12:43 AM
Link wrote:This is what I had always glibly assumed, too, but I have come to believe just the converse, at least for myself. When you start subtracting things, the process forces you to consider each and every item you are deleting. Do you need it right now? Might you ever need it later? There is always the lurking fear that if you don't need it now, you MIGHT, and so the temptation is just to leave it in. Then, not only is the file size significantly larger, so is the visual clutter. You end up with a very complex set of views, layers, etc. that you are always having to scroll through.
2016-08-12 07:32 PM
