‎2009-10-01 04:47 AM
‎2009-10-11 01:50 AM
lec1212 wrote:No, not at all. All of the Favorites will be there ... but will refer to library parts in the 12 or earlier library. So, all Favs for walls, columns, etc will be just fine. It will only be the Favs for library objects - notably windows/doors - that would have to be updated if you want them to refer to the corresponding 13 library parts. Same migration issue as all prior versions.
So all my favorites settings GONE
in upping to 13?
lec
‎2009-10-11 01:53 AM
‎2009-10-11 02:58 AM
‎2009-10-11 03:41 AM
Arcadia wrote:Any attributes (such as those) will be present when you open the file. Nothing new - whatever was there will be there.
What happens to complex profiles and composites that have been set up?
‎2009-10-12 10:00 PM
‎2009-10-12 10:42 PM
Arcadia wrote:Graphisoft does not distinguish between new and upgrades (other than the delivery of a protection device with a new license). The package and disk are the same. Any licensed user may legally run all prior versions of ArchiCAD that their protection key is compatible with.
And will the package I get from Archicad as a select client be upgrade software or a new package? Ie can I run both v12 and v13 on my system for a time as needed. Maybe I should ask graphisoft this question but I usually get quicker answers from this board than them.
‎2009-10-12 10:59 PM
‎2009-10-13 09:17 PM
‎2009-10-14 02:30 AM
‎2009-10-22 07:34 AM
Skaman40 wrote:only received v13 couple of days ago, so haven't tried this; therefore, based on nothing but speculation:
Now migrating an existing Teamwork project into AC13 is a different story...
