Project data & BIM
Hotlink Module Dose Not Work with Trace?
I have hotlinked a two story (pln) building, floors -1 & 1, but when I am in 1st floor of host using the Trace "Below Current Story" the -1 story Does Not show up. Layers and elements are all on. In project Map floor -1 is visible & in the original Module (pln) it shows!
Any thoughts why?
Joseph
3 REPLIES 3
Do you have another floor between -1 and 1 ?
If so it can't show up in TRACE.
And if you, you can right-click at floor -1 and choose show as trace ref....
Hope it helps....
cheers
In the host file if you go down to that Floor, does it show?
Or after you used that -1 floor as Trace Reference, click the Switch Reference with Active button in the Trace Reference Palette. Does it show then?
Sorry Sorry,
Problem was that I did not click on Reset to Default Position
