2006-08-11
01:46 PM
2023-05-26
03:28 PM
Rubia Torres
2006-08-11 05:22 PM
nats wrote:The Project Info has default fields for all those values, and you can make up as many more as you like. They can then all be placed as autotext. Look under the file menu for the Project Info box.
..But the layout architect, date, and revision number are the problems because there are no corresponding entry boxes for these in the layout settings box. Is there any way to set these up or do they have to be typed in as normal text items?
2006-08-11 06:48 PM
2006-08-11 09:51 PM
2006-08-11 10:18 PM
2006-08-12 12:07 AM
nats wrote:Hi Nats,
Yes I know about the Project Info Box but the problem is that putting it in the project info will mean it is the same for every drawing in the file and obviously you need the individual drawings revision, author, date etc info to be different for each drawing. They really need to be provided in the layout settings not the project info, but they arent. In fact providing the issue date, architect, and any other drawing centric info as opposed to project info in the project info is non-sensical and I cant see the point in having this info where it is.
What Graphsoft need to do in order to get such data working correctly is have the project info only include the practice details, client, project number and project name, but have the layout info for each drawing include the drawing number, architect, drg creation date, scale and revision letter.
Thats how every architect Ive ever worked with has had their title sheets set up. I'd like to see how a title box could be made to work with the present settings as they stand.
2006-08-12 09:07 AM
