Project data & BIM
ArchiCAD 21 - Break Hotlink button
fuzzytnth3
In previous ArchiCADs you could Break a Hotlink Module by bringing up the Hotlink Module settings. Now in AC21 however that button has gone and seems to been replaced by a context menu item but it doesn't work as it makes ArchiCAD crash.
Please could Graphisoft fix this and or give our button back, thanks
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
1 REPLY 1
Yes, it seems that in ARCHICAD 21 the "Save as File" button and the "Break Hotlink of Selected Modules" checkbox of the Hotlinked Module Settings Dialog have been removed from the Dialog and became two separate commands available both in the File menu and in the context menu of the Hotlinked Module.
However, the command works fine for me, I do not see any crashes when using it.
This may be file-specific, you should report it to your local reseller.
