Paopao
Archicad 18 code names for layers (AF-1 to AZ-84)
I am still using Archicad 18 and one of the new features I have noticed is the presence of a massive quantity of layers each with a code and a name. I am interested in understanding the coding behind the naming so that I can navigate the layers manager with more ease. Is there a reference or an article explaining all the codes? I have checked the online guide but I haven't been able to find anything.
PS: the codes I am referring to are things like: AF-19, AZ-8, etc...
thanks
Pao
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
6 Replies 6
Layer names are not part of ArchiCAD, but rather part of the file you are working on. If you started a fresh project from a Template in the start dialog - then those layer names were created for the Italian version of ArhicCAD and you would have to contact Graphisoft Italy to ask them what their logic is. The USA template uses entirely different layer names... as does the INT (International) version, for example.
If you opened a file that you received from someone else...then those layer names come from that person.
Paopao
Thanks! You are right, a template was loaded some time ago!
Now the question is: hod do I get back to "normal"? ....
David Maudlin
Paopao:
Click on the File menu while holding down the Option key, New... will change to New & Reset All, this will open a blank template file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Paopao
Thank you David,
I did try it but the template is till there...
Paopao
I have just deleter the whole content and overwrote the original Archicad template. Probably opening the template overwrote the original Archicad blank template.
David Maudlin
Paopao:
In the US version, the templates are at: Applications > Graphisoft > ArchiCAD 18 > Defaults > ArchiCAD; you could try opening the template directly. You could ask another Italian user for the template. You can install ArchiCAD again to a new location (I would use the Desktop), then move the newly installed template file to its correct location in the Applications > ... > ArchiCAD folder.
David
