‎2017-06-28 02:20 PM
‎2017-06-29 03:11 AM
‎2017-06-29 07:00 AM
‎2017-06-29 02:19 PM
‎2017-06-29 05:54 PM
David wrote:Excellent--thanks, David. I've never noticed that. Right in the WE ready for revision. Much better than a list.
Dave:
It is sort of there: Work Environment > Command Layout Schemes > ToolbarsandMenus > List: All new commands in alphabetic order.
‎2017-07-03 01:26 AM
‎2017-07-03 06:37 PM
allanp wrote:Yes, I do the same--not just with the WE, but our entire project template. It's tedious. Just looking for a simpler, less time consuming solution.
You may also want to check the short cut keys
Work Environment > Shortcut Schemes > Keyboard Shortcuts> List: All new commands in alphabetic order.
same list, but in the "Keyboard Shortcut Preview" at the bottom, with "Show Shortcut List in Browser"
I copy that from the browser into an excel spread sheet to identify any changes or added shortcut keys that may affect our company standards.
P.S.
I always build a new work environment in the new version of Archicad, adding the features that are standard to our workflow.
It is hard to identify the changes that might effect new tool usage until the software has been used for a while in the company,
so I always start from the Graphisoft base, and build a company specific tool bar that allows us to do our work faster, rather than trying to add in all the new features to an existing work environment.
also, changing the work environment too much makes it hard for someone to look something up in the Archicad Reference Guide, or to ask question online because i may not know about every feature that was available.
(I know the manual is now only 3380 pages now, but I may not get a chance to read it all before releasing a new template, lol)
‎2017-07-03 06:59 PM
Dave wrote:1. Open your AC20 template in AC21.
‎2017-07-03 07:06 PM
Richard wrote:Yes, Richard, correct. My "tedious" comment really related to the entire template revision process from version to version, of which WE update is a small part--and one of the simplest at that.Dave wrote:1. Open your AC20 template in AC21.
2. Overwrite the AC20 Tool Schemes and Command Layout Schemes with the new AC21 Tool Schemes and Command Layout Schemes.
3. Modify WE as desired. Done.
‎2017-07-03 09:00 PM
