2020-07-15
04:17 PM
2023-05-20
12:05 AM
Gordana Radonic
2020-07-20 09:08 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-07-20 10:54 AM
2020-07-20 11:52 AM
Minh Nguyen
GRAPHISOFT
2020-07-20 12:35 PM
One more question: how did you create the BCF file? By using Solibri, or is there any extra addon used for this process?This has been done nativly in Solibri - no third party software included into the described workflow.
2020-07-20 02:31 PM
Minh Nguyen
GRAPHISOFT
2020-07-23 09:36 AM
Minh Nguyen
GRAPHISOFT
2020-07-23 11:14 AM
mnguyen wrote:Thx for clarifying that, as I have understood this means that all AC24 Projects with a custom SP are affected when it comes then to BCF Import and only a workflow where the project is in the "actually wrong" default orientated zero origin location is working because then this bug is of course not occuring as the BCF will imported alright as it doesn't matter that the SP is ignored.
Our developers have checked the issue, and found out that this is a regression bug in Archicad 24. This issue was a problem in Archicad 23, and was fixed already, but somehow, the fix was not copied to Archicad 24! The issue happens due to the fact that the SurveyPoints are not calculated when BCF is imported in Issue Manager.
In the meantime, there is a workaround, but it is not so pretty: move the Survey Point on project origin (0,0), rotate to default Project North which is 90 deg, then re-export the model to Solibri, then re-create the issues, after this the exported BCF will be ok in Archicad.
mnguyen wrote:Well, ok, at least we know what's going (wr)on(g) and let's hope indeed for a quick fix!
I create a defect entry in our database for this issue. Hopefully this will be a quick fix!
Thank you very much for reporting this issue to us! Let me know if you have any further question!
2020-07-23 11:18 AM
Minh Nguyen
GRAPHISOFT
2020-07-23 11:28 AM
