We create structural drawings from our model. What you describe is only possible by stacking several different saved views with graphic overrides.
However, once you've set this up in a template, it gets easier with new projects going forward. This doesn't help your current project obviously.
You need three model view option combinations:
1. one where you show doors, windows, skylights as opening only. You should be able to set the detail level of windows to show reveal settings
2. one where you hide all the openings
3. one where you show openings with contours
We have 11 Graphic override combinations:
1. Roof view
2. Foundations
3. Facades
4. Roof structure
5. Beams
6. Piles (foundation)
7. Trusses
8. Structural walls
9. non structural walls
10. schematic walls
11. dashed line walls
12. floor (slabs)
The rules we have sort out things like:
1. show outlines in a bolder / thicker line for elements
2. show elements dashed
3. hide cover fills
So for a typical story we have:
A saved view from one story below that shows the outer walls with dotted lines
A saved view that shows the structural walls from one story below with dotted lines
A saved view that shows the floor (slab) and the structural walls on that story
A saved view that shows (schematic) the non structural walls on that story
A saved view that shows the roof on that story (if you have a pitched roof)
A saved view that shows the beams by having a very high cutplan so it projects beams as needed
We have annotation layers for each different layout / story for structural drawings specifically. Layer combinations set up for these.
It would take me a long time to list out all the saved view settings with all the graphic overrides, rules etc, but I hope you get the basic idea.
It can be done, but it's not ideal. We do this with a smaller structural engineering firm that outsources their drawings either way, so we keep a bit of extra revenue from client by also doing the structural drawings. Our ArchiCAD models are very detailed, without wanting to brag about my own work
, so it's very easy to generate the sets since we've put pre-linked layouts and view sets in our template. The real work is annotation, which generally takes maybe 1-1,5 hours per layout.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
