Project data & BIM
Architectural 100 Penset
KeesW
Does anybody use the architectural 100 pen set? It is supposed to be an internationally developed combination of lines and colours. Cadimage use it as the basis for their tools but are there any others doing so? Whilst extremely rational, It is also very complicated, unintuitive and unlike any other combinations that I have ever seen. ArchicadWiki has a good description of it.
I've just received AC15 and it doesn't have it, or anything like it, in its options.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Laura Yanoviak
Huh -- I've never heard of it, but will look into it -- thanks.
Laura Yanoviak
My observations after a first glance:
First, the AC15 template does not contain all of the Pen Sets listed.
Second, it seems odd that the "Architectural 100" set is listed as the default.
Third, the AC15 library doesn't seem to use the "Architectural 100" set, in which case I'd stay away from it until it does.
KeesW
That is why I thought - nobody uses it!
I'll take it up with Cadimage.
