Project data & BIM
Atribute Manager and Layer folders
Jp1138
When importing our Archicad 26 template into Archicad 27 using the atribute manager, it has come to my attention that you can´t import layer folders:
That is making all our layers combinations unusable in 27 until we manually recreate the folders we had in place in 26 and put everything in its place.
Am I missing something or the whole layers folders structure cannot be imported through the atribute manager?
ARCHICAD 27 SPA
Windows 10
The old Attribute Manager can not handle attribute folders.
Use the new Attribute Palette and you have the option to import with or without folders.
Jp1138
Oops. Totally not though about that. Thanks!
ARCHICAD 27 SPA
Windows 10
