‎2023-11-13
12:00 PM
‎2023-12-04
02:15 AM
When importing our Archicad 26 template into Archicad 27 using the atribute manager, it has come to my attention that you can´t import layer folders:
That is making all our layers combinations unusable in 27 until we manually recreate the folders we had in place in 26 and put everything in its place.
Am I missing something or the whole layers folders structure cannot be imported through the atribute manager?
Solved! Go to Solution.
‎2023-11-13 12:43 PM
The old Attribute Manager can not handle attribute folders.
Use the new Attribute Palette and you have the option to import with or without folders.
‎2023-11-13 12:53 PM
Oops. Totally not though about that. Thanks!
