Jp1138
Atribute Manager and Layer folders
When importing our Archicad 26 template into Archicad 27 using the atribute manager, it has come to my attention that you can´t import layer folders:
That is making all our layers combinations unusable in 27 until we manually recreate the folders we had in place in 26 and put everything in its place.
Am I missing something or the whole layers folders structure cannot be imported through the atribute manager?
ARCHICAD 29 SPA (as long as the server works)
Windows 10
1 Solution
The old Attribute Manager can not handle attribute folders.
Use the new Attribute Palette and you have the option to import with or without folders.
Go to post
2 Replies 2
Jp1138
Oops. Totally not though about that. Thanks!
Windows 10
