Attribute Manager - Materials
is it a bug or why can't I download Material texture settings from another file? I get only the other settings for material, not the file settings..
/Tobias
5 Replies 5
I found a solution.
Open original file : save as *.aat file
Open new file and import *.aat file and then it works.
/Tobias
Somehow related: how should one handle composite names as they evolve over time?
After several years of working pretty much on my own with my own fairly-fine-tuned system, I am now working as part of a team where composite definitions have been evolving over time, appearing during the process in different files and projects (sometimes it is the composite dimensions and fills that change a bit, sometimes it is pens only).
The problem is that when you import attributes or get a module or copy-paste an object from another file that has a 'different' composite by the same name you end up getting, for example, '4 in gyp' and '4 in gyp (1)'. Which is very upsetting and disconcerting. You don't get a warning asking if you want to replace etc.
Starting fresh from templates and attribute files keeps you safe with new stuff. But should one also add a date or version to the composite name in order to avoid this type of problem when reusing old stuff?
The problem is that when you import attributes or get a module or copy-paste an object from another file that has a 'different' composite by the same name you end up getting, for example, '4 in gyp' and '4 in gyp (1)'. Which is very upsetting and disconcerting. You don't get a warning asking if you want to keep the old, replace with the new, or rename the new.
My problem was that when I made my template file for AC9 all texture settings disappear and I don't want to start from scratch too do a new template when I use AC9 default material settings. But that problem is solved.
But I'm agree with your post. Maybe a possibility too write longer composite names than it is today? Today we can't write complete definition in composite name.
Hope you understand my sometimes bad english.
/Tobias
Couldn't this be avoided by having a set of .aat's on the company's server? If loading the composite's full .aat when starting up a new project (from a company template) everybody will have the same sets. If a new composite or an existing one needs to be adjusted, give it a new name + export/update the servers .aat so that the rest of your co-workers can up load the new composite.
Also, could you a more specific system of giving (both new and old) composites names? This way it will be easier to define similar composites that f ex only have a slight difference in thickness of one material ...
