Hi Cam.
We have been able to manage the problems (we are still dealing with the same project).
We still have like 5 active PLPs that are"connected" trough mod files that have been updated once every 3-4 days.
The documentation tasks stays on the other 30 PLN layout books. Now the difference is that we do not link the drawings directly to the PLPs ,we are publishing the views as PMKs, and then these are placed on the layouts as drawings.
I have to tell you that this works much faster, really faster. But.... there is always a BUT... 80% percent of the times we can not update the drawings, from an updated PMK, because the the drawing disappears. Of course it does not disappear, but is moved out of your pre-defined frame, and then you have to set it to "fit frame to drawing" and "zoom to fit" and try to find the drawing.
That is why most of the times we just delete the old drawing and place a new one (the same one).
This is a really waste of time, because if the drawings were working correctly , we could just update the PMKs, and then update the drawings from the drawing manager.
I agree with you that This software has very nice things, really nice things... that works only some times an under certain limits. (when is not the polygon count, then is the amount of 2D lines, or the File size, or the number of team mates, or just a Bug)
There is not a tool 100% reliable.
Some times it works, some times it doesn't, and you expend too much time just figuring out what is happening.
But i still like it more than Revit ....which have really nice things too. (i have worked on a couple of projects with Revit)
Regards
Nando
	Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
