justdhruv
Bimserver not accessable.
My bim server is not accessible. Any ideas?
I have reinstalled it couple of times. I am running another bimserver for AC21, just fine
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
2 Replies 2
Hello justdhruv,
BimCloud software is on your computer ?
BimCloud software is on another computer ?
BimCloud is into your office or far far away ?
Are your collaborators far far away ?
If you try to do remote work for a collaborators.
Your modem is like a security guard who protects your client's home network.
To access a computer station (BimCloud server for example) you have to know :
- your client's modem public IP (and not its local IP)
- your client's BimCloud port (80 like example below)
- change client's modem port parameter to allow access
You may be at the computer at the bottom right
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Noemi Balogh
Did you configure an external location for your snapshots?
If your answer is yes, then the issue is that you turned on a BIMcloud only feature in BIMcloud Basic, which blocks your BIMcloud Server to run.
Please check out: https://helpcenter.graphisoft.com/knowledgebase/87062/
Kind regards,
Noémi Balogh
Senior Community Expert, Admin
