justdhruv
Bimserver not accessable.
My bim server is not accessible. Any ideas?
I have reinstalled it couple of times. I am running another bimserver for AC21, just fine
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
2 Replies 2
Hello justdhruv,
BimCloud software is on your computer ?
BimCloud software is on another computer ?
BimCloud is into your office or far far away ?
Are your collaborators far far away ?
If you try to do remote work for a collaborators.
Your modem is like a security guard who protects your client's home network.
To access a computer station (BimCloud server for example) you have to know :
- your client's modem public IP (and not its local IP)
- your client's BimCloud port (80 like example below)
- change client's modem port parameter to allow access
You may be at the computer at the bottom right
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Noemi Balogh
Did you configure an external location for your snapshots?
If your answer is yes, then the issue is that you turned on a BIMcloud only feature in BIMcloud Basic, which blocks your BIMcloud Server to run.
Please check out: https://helpcenter.graphisoft.com/knowledgebase/87062/
Kind regards,
Noémi Balogh
Staff Community Expert, Admin
