GaryJ
Bom Server and BIMcloud - self service
I've been running a BIM server since 2018, but I just upgraded team's archicad licences to archicad 27/28.
I don't want to pay for BIMcloud seats and am happy to keep my personal server in the process.
The team will all use the same version of Archicad across the floor.
Do I upgrade the old bim server that has operated without restarting or updating for about 4 years now to BIMcloud Basic - BIMcloud-GEN-2024.1-28.0.567.5208-1.4 with Archicad 27?
thanks in advance
Gary
Operating system used: Mac Apple Silicon sonama
1 Solution
scottjm
Mentor
You need to install a new instance of BIMcloud basic Manager and Server.
During the setup process you will set which version of Archicad you want to use ie 27.
you can’t change the linked Archicad version of any existing BIMCloud Basic server.   This is independent of the version of BIMCloud you are running.   One of the limitations of BIMCloud basic is only being able to run projects from a single version of Archicad per server/manager instance.
Go to post
5 Replies 5
scottjm
Mentor
As Scott described you have to setup a seperate BIMcloud Basic server for every version of AC.
We were happy as we were finally able to take at least the AC 19 server out of comission 😉
AC 6,5 - 28 | GER WIN | i7-9700K | RTX 3070 | 64GB
GaryJ
Thanks!
Easy enough to manage. Eventually I set up a new light sail instance, opened a couple of ports, installed the bimcloud for v27, and generated a fixed IP and a domain name. I guess, one for each version of ArchiCAD.
GaryJ
Ok! The biggest hurdle was upgrading the windows server version. I was running windows server 2016
we have all bimclouds running on 1-2 servers, differentiate by differented by according port numbers. AC 22 -> port:22000, AC25 -> port: 25000 etc.
