Project data & BIM
Can't seem to find property GUID in a project
Otavio Augusto
To find the property GUID, I usually use the 'property label 26' in an object, select which property I want, and save it as a custom label. So, when I open its GDL 2D code, I can find the selected property GUID to use in other objects that I'm creating. However, in this frustrating project (which predates my template in the office), when I save the custom label, it doesn't show any GUID. Does anyone know why or another way to find a property GUID?
Just to illustrate what i'm saying:
this is when it works, and the following images are when it doesnt work...
whyyyyyy
Actually wasn't happy that the GUIDs can't be easily copied so I updated the object to be able to select the properties in the label settings and you can easily copy the GUIDs from there. The new object is attached to this post.
Code
Need 2 parameters named myProperty1 and myProperty2.
UI-Script
dim _parentProperties[]
n = REQUEST ("Properties_Of_Parent", "", _parentProperties)
ui_custom_popup_infield "myProperty1",
	200, 10, 250, 20, 	! X Position, Y Position, Width, Height
	1, 					! Store Hidden ID
	3,  				! Tree Depth
	1,   				! Grouping Method
	"",   				! Selected Value Description: same as the ID
	_parentProperties
ui_custom_popup_infield "myProperty2",
	200, 40, 250, 20, 	! X Position, Y Position, Width, Height
	3,  				! Tree Depth
	_parentProperties
foundProp1 = 0
foundProp2 = 0
for i = 1 to vardim1(_parentProperties) step 4
	propertyGuid = _parentProperties[i]
	groupOfProperty = _parentProperties[i+2]
	propertyName = _parentProperties[i+3]
	if (propertyGuid = myProperty1) then
		foundProp1 = 1
    	ui_outfield propertyName, 10, 10, 180, 20
	endif
	if (propertyGuid = myProperty2) then
		foundProp2 = 1
    	ui_outfield propertyName, 10, 40, 180, 20
	endif
next i
if not (foundProp1) then
	ui_outfield "Please select a property", 10, 10, 180, 20
endif
if not (foundProp2) then
	ui_outfield "Please select a property", 10, 40, 180, 20
endif
2D Script
foundProp = 0
	if (propertyGuid = myProperty1) OR (propertyGuid = myProperty2) then
    	foundProp = 1
		text2 0, 0, groupOfProperty + " - " + propertyName
		text2 1, -1, propertyGuid
    	add2 0, -3
	endif
next i
if not (foundProp) then
	text2 0, 0, "No property selected!\nPlease go into the label settings and select a property!"
endif
Edit (2023-10-26): Renamed object to "GetPropertyGuids.gsm" to better denote the use case. Also compatible with AC24+ now.
Hi Otavio!
Not sure why your way is not working, but I've attached you a label object which can give you the property GUID in a different way.
Just use it to label some element which has access to the properties, similar to my screenshot:
To make the object yourself, you can paste the following code into the 2D script of new label object.
	if (propertyName = "TAG ACABAMENTO #1") OR (propertyName = "TAG ACABAMENTO #2") then
    	add2 0, -3
	endif
next i
Hope that helps!
Bernd
Code
UI-Script
	3,  				! Tree Depth
	_parentProperties
	3,  				! Tree Depth
	_parentProperties
foundProp1 = 0
foundProp2 = 0
		foundProp1 = 1
	endif
		foundProp2 = 1
	endif
next i
endif
endif
2D Script
foundProp = 0
    	foundProp = 1
    	add2 0, -3
	endif
next i
endif
WOW, that's awesome Bernd! thank you so much!
This is really waaaaaaaay easier, i can't express my gratitute enough!
