ej
How to flip the "2d plan preview" of doors in schedules?
Hello,
I want to flip the "2d plan preview" of doors in a schedule, thus the floor plan preview would display the hinge on the same side as the "View from opening side", is this possible?
AC 25
macOSmontery (12.3)
1 Solution
@runxel wrote:
Hey Barry, I think it should actually work…
I have no Archicad in front of me right now, but GLOB_PREVIEW_MODE is the thing the OP is looking for. It would give “2” in the IS.
Sure you can do it in GDL, but I didn't want to mention that.
It means ej will have to edit the default library objects (possibly every door and not just a macro?) - I am assuming ej is using default library doors.
Then if ej re-saves the original objects, they will have to go through the same process if there is a library update or for each new version.
Go to post
5 Replies 5
The plan view can not be rotated.
It is simply the default 2D view of the door object as it has been scripted with left or right handing.
runxel
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
runxel
Yeah, you're right. I'm sorry, @Barry Kelly + @ej.
I was somehow under the impression we're talking about GDL programming and ej's own doors..... 🤦🏻‍♂️ My bad!
So to conclude: It's possible, just not really for the everyday user, sadly.
ej
Thanks for the responses!
Yea, im using standard library doors,
its nice to know you can change it but I will not create my own doors for now.
AC 25
macOSmontery (12.3)
