fuzzytnth3
Change Marker Tool
I'm having a problem where some of my Changes do not show their revision cloud but others do. Can someone tell me what is going on?
Thanks
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
2 Replies 2
You mean that there are no bubbles in the cloud and it is only straight line segments? That usually happens when the cloud shape is set to Polygonal, but that is not the case on your screenshot.
Can you transfer the parameters of another Change Marker that works? Or delete it and recreate it?
fuzzytnth3
A colleague sussed it out. In the Issue Settings you can choose to only the current issue back to only a certain issue or only the current issue. The Change Markers that were "hiding" their polygon lines were from a previous issue and the Issue Settings were set to show only the current issue.
