ananas
Change element types
Hello
Is it possible to change element types? I have some walls built with morph tool, but would like to show them as Wall in the lists.
Thank you! 🙂
2 Solutions
Jonas Krieg
Dear tjasa
You cannot change the element type, because it's defined by the tool you draw the element.
Instead, you could use the "Element Classification" and classify your elements (walls and morphs) as walls and finally choose that classification for your schedule.
ArchiCAD 27
MacOS 15.0
Go to post
Jonas Krieg
It's called "Klassifizierungen" in german. Maybe you have more than one classification system, so be sure to choose the correct one!
Good luck 🙂
ArchiCAD 27
MacOS 15.0
Go to post
4 Replies 4
Jonas Krieg
Dear tjasa
ArchiCAD 27
MacOS 15.0
ananas
Hi Jonas!
Thank you vry much for your answer,
I don´t find "Element Classification" in the list criteria ... Do you maybe have time to show me where it is/share a printscrean?
That would be great! 🙂
Thank you.
Jonas Krieg
Good luck 🙂
ArchiCAD 27
MacOS 15.0
ananas
Oh, I see, I found it!
Thank you!
