Project data & BIM
Changing line weights...
If I were to assign different layers to different sets of lines (similar to what you would do in CAD), is there a way to change the line weight of a layer? Or to select an entire layer and change the line weight?
For some reason I can't figure out how to make this happen, but it seems like this would be possible. Basically I'm asking if ArchiCAD can work similar to CAD, only when I prefer to draw using lines, which is rare, but convenient at times.
Thank you in advance!!
It's important to note that ArchiCAD uses layers differently than AutoCAD. Layers are entirely used to hide or display the object, but do not control anything else.
For line-weight, they're controlled through the use of pen sets which act a lot like layers except they don't control visibility. You can sort of think of AutoCAD layers being a combination of an ArchiCAD layer and an ArchiCAD pen set. This allows for flexible control over how elements are displayed, but does cause a bit of confusion for folks switching from AutoCAD.
This can ease collaboration since some disciplines have different requirements for lineweight than others. For example the Architects in my office use pen 37 for interior walls. In their drawings, they're using color and a heavy lineweight as defined in the pen set they created for their drawings. In my drawings however I require grayscale and hairline for walls since they're a secondary feature. Rather than having to move all the walls from one layer to another and incurring the wrath of an Architect who's just had all the interior walls disappear, I change the pen set of my view and the walls look right since the pen set decides how pen 37 is displayed, not the layer or some hard-coded part the object.
Oh, and you can search for objects by layer (and/or pen) using the "Find & Select..." tool in your edit menu.
While it may be partly possible to do what you want, don't do it. While it is very useful in AutoCAD, ArchiCAD is not designed to work this way. Pens BY LAYER is not necessary. Learn ArchiCAD the right way or you will be struggling for a long time.
Well of course learning it the right way was my intent. I didn't mean to sound as if I have no experience in ArchiCAD at all, I actually have a good 2 years of consistent experience with the program, but never really needed to use pens similar to AutoCAD until now.
The 'find and select' feature works nicely, so thank you to the previous poster! Thats really all I needed.
