Hello Kevin Rozon,
Why do you use IFC instead of .mod or .pln ?
And here is the way to prepare a IFC translator to change renovation about an IFC hotlink :
Some explanation about IFC :
The IFC2x3 standard includes a main MVD :
Coordination View V2.0 :
this view was designed to coordinate the three main models of project design: the architectural model, the structural model and the fluid model.
And IFC4 :
Reference View 1.0 :
intended for one-way exchanges, the file issuer remains the owner of the model. It guarantees the geometric consistency of the model and the basic quantities, but it is not possible to retrieve or modify the objects in the model.
Design Transfer View 1.0 :
keeps the editable character of the IFC elements to the maximum and therefore allows posterior intervention on the model with the possibility of adding, deleting, modifying or extracting elements. Model ownership can be transferred.
Christophe - FRANCEArchicad Designer and Teacher
Archicad 15 to 27 FRA FULL
