CineRender Import Textures from Internet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-07-16 01:29 AM
Also, what is the difference between the pre-set scene and the pre-set scene (physical) I don't see one in rendering or speed.
M1 Macbook Pro
- Labels:
BIM Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-17 09:28 PM
M1 Macbook Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-17 10:53 PM
As for the "physical" setting it just means on how you specify the camera settings for the rendering which should match real life cameras were you specify ISO, F-Stops and Aperture instead of using percentages. The other item were physical applies is refers to the Sky were you can use the physical version or a HDRI map.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-11-20 03:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-19 06:17 PM
it looks like the only way to do it,
it might be possible (not tested) but this transfer via cinema4d would be very long and surely with some issues (files links.., settings a bit different)
then this may not be a solution to the actual lack of other textures in cenerender with archicad.
i read there wer to be some in bimcomponents online library, but i found none!
how is that?
anybody could help further?
thanks, bye
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-20 03:29 AM
BMASH wrote:I just had a look and could only see 12 'surfaces' in BIM Components.
It seems they don't have keywords attached (like 'C4D') which would make searching easier.
Otherwise just search for 'surface' and look through the whole list.
If you have an SSA (Select Service Agreement) you will be able to download another 500 or so.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-20 09:55 AM
i don't have a ssa; the 'aditional surface catalog' was first downloadable without ssa. maybe some guiy would like to share?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-20 10:10 AM
BMASH wrote:Be sure to keep pressing the 'Show More' link.
yes, but in bimcomponents, i'm only able to see 2/3 of them..
2 grass and a brick surface show up front - the attached image shows those hiding at the end of the list when you search for 'surface'.
BMASH wrote:No it is only available for those with an SSA unfortunately for those without it.
We need some sort of perk for paying for future upgrades up front.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-21 03:35 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-07-27 09:59 PM
Start a blank project,
Load the *.lib4d file (this will import all materials into C4D),
Save project as *.C4D,
In ArchiCAD,
Open "Surface Settings",
Engine settings: Select "CineRender by Maxon",
Under the left menu list select "Match Settings",
Load *.C4D File.
Done
