fontanaluca
Correct the Italian translation of the material "aluminum" from "aLuminio" to "aLLuminio"
There is a problem with the Italian version of ArchiCAD and its template for the material aluminum, translated as "aluminio". But "aluminio" doesn't belong to the Italian language. The correct word is "alluminio" with two "l".
Karel Landa
This is a wishlist forum where users should write their ideas on features to add.
If you found a bug or and mistake in the program, you should report it in the correct forum or contact your local reseler who does the translation in this case.
From Archicad 17
MacBook Pro M1 Max
I moved the post from the Wishlist to the relevant forum.
