‎2004-08-06
06:37 PM
‎2023-05-30
01:15 PM
Rubia Torres
‎2004-08-06 09:35 PM
‎2004-08-09 08:54 PM
‎2004-08-09 09:47 PM
‎2004-08-09 10:16 PM
True story: I just did this for my templates today!James, tell me you simply copied & pasted the existing masters to duplicate them in order, then used Trees By Masters to reassign them?
I guess I should clarify question 1: I'm referring to the titles of the views, for example "concept set," "permit set" etc. I seem to be unable to change their order even by adding a 'space' in front of the word so AC thinks it comes first alphabetically.Gregory, if you are referring to subsets, they can be dragged around willy nilly! The only exception is that you can't drag a folder below a folder that is expanded. This is a bug. It may serve you better to un-expand(?) your subsets before trying to drag them within the Navigator. Apart from that, it is very much like dragging folders around in your OS. You can even right click /ctrl click to drag copies.
‎2004-08-09 10:42 PM
Gregory, if you are referring to subsets, they can be dragged around willy nilly!Hi Link,
‎2004-08-10 03:07 AM
Link wrote:No, I'm talking about the AC view sets. I only use a handful of masters, so they've never bothered me much.
James, tell me you simply copied & pasted the existing masters to duplicate them in order, then used Trees By Masters to reassign them?![]()
‎2004-08-10 03:08 AM
