Customize information displayed
Hi all,
I am just started using ArchiCAD. I know about the "Zone" features that able to display some information about that zone, for example, area, etc. I know it is possible to print that information in txt format. Where can I customize the information I want to be printed out/displayed? For example, I want to have other information such as perimeter and so on? Where is the setting?
3 Replies 3
Rod Jurich
scct wrote:
Hi all,
I am just started using ArchiCAD./.... Where is the setting?
If I understand your query correctly, you may look at the attached.
Rod Jurich
Thanks. That's what I am trying to find. I thought it will provide information about coordinates too. Is that possible to have the information about the coordinates too? I desperately needs the coordinates info.
Many thanks.
http://www.archicadwiki.com/Global_GDL_Parameters
and
http://www.archicadwiki.com/Zone_Fix_Parameters
These contain GDL Global Variables that provide information about elements, including Zones.
You could assign their values to parameters in GDL, and list those Parameters with Interactive Schedule.
