Project data & BIM
Deleting Zone Categories Causes Archicad to Crash
Aaron Bourgoin
I am unable to delete unused Zone Categories without the file crashing. Have tried this via the Zone Categories dialog and via the Attribute Manager.
Has anyone else experienced this? If yes, have you been able to figure out a solution?
Operating system used: Mac Intel-based Sonoma
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
5 REPLIES 5
I assume you are talking about version 27?
I just tried (Windows machine) from zone categories dialogue and it did not crash.
I only have build 5030, have not yet upgraded to 5060.
used to be kevin b
I am running into the same problem when using AC27. I just downloaded 28 and haven't tried there yet. Anyone ever find a fix for this?
kevin b
AC28 (3001 USA Full), since AC6
Windows 11 Pro
Intel Core i7 -12800H @ 2.4 GHz~ 64 GB ram
KB-at-CWA
This is still happening for me. This needs to be addressed ASAP as it is wasting so much time and hot linking is next to useless.
Is there any way that Graphisoft can respond to state that they are looking into this? I feel that issues like this are just ignored.
Graphisoft Certified Archicad BIM Manager - AC6 to AC25/AC26 macOS Ventura
This has nothing to do with hotlinking, so I don't know why that was mentioned here.
Have you reported this to your local support and discussed it with them?
That is what they are there for.
Can confirm that the file I was most recently having crashing issues in AC27, I opened in AC28 and was able to delete the Zone Categories without issue.
kevin b
Windows 11 Pro
Setup info provided by author
