Display of door tags in a mod file
Hi All,
I have a question. In a pln. file ( Archicad 24) I have turned off all my door tags ( the default ones) .
If I import that pln. (as a mod. file) it brings in the doors showing the door tags.
How can I rectify that?
Looking forward to your feedback.
Regards,
Mel
2 Replies 2
Lingwisyer
Guru
Did you turn them off in object or through the MVO settings?
Ling.
If you are controlling the 'tags' (markers) by the Model View Options, then you will need to make the same MVO settings in the parent file as well.
The MOD file will simply adopt the MVO settings of the parent file.
