Project data & BIM
Display question in 3D and Elevations
I am having problems displaying elements correctly in 3D views, elevations and sections.
When I put elements of de same class and material close together, the line separating the disappears.
While I understand that this feature can help many times, there are situations where you want to show every element.
I attached to pictures to make it clear.
Maybe somebody knows how to do it without having to separate the elements in different layers or editing their intersection number ?
Thanks!
5 REPLIES 5
Thanks!
The line will show up in the 3D window if you turn Contours on.
Layers / intersection number is the typical way to accomplish this for sections/elevations/3D Documents. The "old fashioned" way that will work for you is to make a duplicate of the material assigned to the adjacent elements and assign one of those elements the duplicate material. When like materials abut each other, ArchiCAD removes the line - this is generally desired in Elevations where walls fit together. But you can force the lines to be visible by assigning a different material, even if it is an exact duplicate. The contour line will NOT show up in a rendering though.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
NCornia
Graphisoft Alumni
Graphisoft Alumni
That is a good tip. It would be nice if there was a global or instance setting that could be checked/unchecked. Similar to displaying the edge contours of adjacent cabinetry.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Hi Karl,
thank you for the trick. Using a duplicated material is indeed a good option. The only problem with this technic is that it makes it a little more complicate to organize the elements by material when crating schedules. You and up having to groups of the same material with different subtotals.
I thing I should be possible to deactivate this automatic mechanism in the object preferences. That would enhance the display possibilities without compromising other organisatory parameters.
Thanks end best regards,
Sergio
NCornia,
indeed ! Thats exactly what I meant.
regards,
Sergio
I agree with all of your points, Sergio!
