Displying composite skins
Using AC10 after a long time away.
Where and how do I control the display of composites.?
No matter where I look or what I do, it only displays the outter contours of the wall. None of the different layers display.
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
I found it ! "Symbolic Cut"
This program sure has bells and whistles!
Link
Conrad,
Try checking the wall's settings. In particular the Floor Plan Display which is under the Floor Plan and Section tab. You might have your walls set to Symbolic Cut, Outlines Only or Overhead All. You really want a projected method for most regular walls.
These are new functions in ArchiCAD 10 and are included to manipulate the diplay of multi-story walls.
[Edit: I see you found it - sorry I was a little late!]
Link.
