Project data & BIM
Duplicated Library Parts in Embedded Library - Template
Hi All,
After updating our ArchiCAD 18 template file to ArchiCAD 20, and cleaning up all missing objects and textures, after a few open and closes I end up with some duplicated library parts popping up out of nowhere. I can delete them but they will return.
Any idea how to prevent this from happening?
5 REPLIES 5
Do you have Hotlinked Modules placed in your file? I think a Hotlinked Module can bring in its own Embedded library.
If you go to the Library Manager, under Embedded library, is there any info about where those files are coming from?
Hi Lasz,
There aren't any hotlinked modules in the file, the image below indicates that there arent even any instance of these objects placed.
2raarchitecture
Following up with this topic. I came across the same problem...
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
@2raarchitecture
Hi.. you are replying to a 5 year old (considered dead) topic.  Please start a new topic with screenshot of what you are experiencing. 🙂 Your signature shows AC 25 build 4013, if you have updated to the current build 5005, please update your signature too 🙂
Karl, thank you kindly for your reply
