Friday - last edited Friday by Barry Kelly
HOw do you edit a schedule tu add criteria to the type? I used to know it
Operating system used: Mac Apple Silicon Monterey
Friday
Open the schedule 'Scheme Settings' and under the 'Criteria' section you will see an 'Add Criteria' button.
Monday
No, I need to add material specifications, such as DF, HF#2, etc
yesterday
I am unclear on what you are trying to do.
Can you share any images or clear examples of what you are trying to do?
You can create Properties for these material specifications, which you can associate to your elements.
Then set the correct property value in the elements.
You can then schedule those elements and their properties.
