Element Transfer Settings Profile for attributes only
This feels like a noob question, but struggling to find a solution.
Wanting to set up an Element Transfer Settings Profile that only adjusts the pens & lines of an element.
Basically, those attributes which are editable when going into the Floor Plan and Section dialogue of an elements settings.
I have created a new Element Transfer Settings Profile, unticked all available items.
When I use this profile, it is still applying other changes, such as the defined complex profile etc.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
1 Reply 1
You can turn everything off, but there is a group of settings called 'Other Settings' that can't be turned off for most element.
I don't know what is included in 'Other Settings' but it is probably more than just the pens and lines.
So I don't think there is much you can do in this case.
