Project data & BIM
Elevation undo
R-G-CAD
Hello, When using Archicad 25 on windows I have noticed something. When an elevation is duplicated then in the navigator new automatic drawings and views are created. When afterwards undo is done (2x or 3x redo/undo) the elevation on the home story is deleted and the automatic drawing/view is deleted/changed into an independent elevation. When this procedure of do and undo is done with a section the drawings and views in the navigator are deleted. Is this behaviour of Archicad of the independent elevation leftover in the navigator normal? Should the navigator be inspected regularly for leftovers?
Could you post a few screenshots that illustrate this behavior?
It is not just version 25 - I just tested in 22 with same result.
If you select the elevation marker in plan and delete, you will be prompted if you want to keep as independent viewpoint.
This does not matter if it is a freshly placed elevation or a duplicated elevation.
The interesting thing is if you place a new elevation and then undo, it deletes and does not leave an independent viewpoint.
But if you place a new elevation, then duplicate it and then undo, the duplicate deletes and leaves an independent viewpoint (without asking you).
I am not sure why this is.
Workarounds.
Undo and then delete the independent viewpoint from the Project Map.
Or don't undo, select elevation marker in plan and delete, then you choose what will happen.
