Josh Verran
Custom Menu for in-house material
I know that it is possible to new menus to Archicad and also the current PDF and website content is located here:
C:\Program Files\GRAPHISOFT\Archicad 25\Documentation
C:\Program Files\GRAPHISOFT\Archicad 25\WWWLinks
When it comes to adding our own content, rather than copy material to the above locations on each and every local PC, there must be a way to designate a custom folder in the Work Environment, the same as we do with Template file locations.
I can't seem to find anything in the Work Environment that allows me to nominate a custom location vs the default location.
The below link describes how to add a menu and choose from existing content but doesn't appear to describe how to add new content.
https://helpcenter.graphisoft.com/user-guide/128968/
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
I wonder if this post helps with what you are trying to achieve:
https://community.graphisoft.com/t5/Setup-License-forum/Error-WWWLinks2-amp-Help2/m-p/330004/highlig...
