‎2006-11-15 04:53 PM
‎2006-11-15 11:18 PM
PivoArch wrote:OK... what are the problems you are having with them?
We could get started here I guess. I would say Object Creation, Fire Ratings, and Demo with Existing are gonna the major ones.
‎2006-11-15 11:31 PM
‎2006-11-16 12:30 AM
TomWaltz wrote:The "ArchiCAD 10 Detailer Users Guide" published by Graphisoft and the accompanying tutorials.
What Detailer Tutorials are you using?
‎2006-11-16 09:46 PM
‎2006-11-16 10:00 PM
‎2006-11-16 11:13 PM
PivoArch wrote:I think the easiest way would be to embed the dashed lines in the composite like you were thinking, then have a different pen set for the Code Sheets than the others. Use a specific pen for the dashed lines.
At the moment my theory on this is to build a composite with the dash in it, now the problem with this is that we do not want to show the rest of the composite on the code sheets (i.e. drywall or cmu). It would be greate if I could customize the model view options to make this work but I can't so....What I am thinking is to create a layer for fire rated partitions that would have walls on it with no height that would use a composite that would be only the dashed lines. Set said layer to a different priority than the regular walls so as not to effect clean ups. Then you layer sets to control the viewing of the walls on the varying sheets. The downside to this is that you must make sure to update the fire rated walls when you update the regular walls. .
‎2006-11-16 11:32 PM
andyro wrote:It would be easier if you could do without the dashed line and just use color. It's more common to just assign specific pens for fire codes, that in the fire code plans show as color for the entire wall, and in other plans are just mapped to regular cut fill colors. See the attached image that shows an example of specific firecode pens in a template.
It worked! So I use the Ghost penset (everything ghosted except this fat FIRE pen, and change the model view options as shown, no need for duplicate walls or linework. Of course the red will print black when the sheets plot.
The question is how to make this line disappear in normal construction prints. Making it grey will still kinda show, unless the particular composite in question has an empty core fill, where the FIRE pen turns white. - Aha. Skin 'Hide' in the composite, and then just make sure your placed fireplans drawings do not update automatically.
A
‎2006-11-17 02:25 AM
‎2006-11-17 03:18 PM
‎2006-11-17 04:09 PM
