2006-11-15 04:53 PM
2007-01-11 09:23 PM
2007-01-11 10:27 PM
TomWaltz wrote:Yeah, GS hasn't fully gotten up to speed with the whole multistory element thing yet - another reason to stick to the old paradigm of walls per story - anyways, if you are doing multistory work, your hotlinks may require this - for example, floor 9-15 are all more or less the same, floor 9 is the one you work on, and floors 10-15 are mere hotlinks. we have always treated hirise and multistory projects in such a way that the floorplate and its walls, exterior and interior are self-contained (in other words, no multistory elements).PivoArch wrote:TomWaltz wrote:Yes you can, but then is actually shows up on all stories. Even if the wall does not.
Can't you set it to "Show on all stories" in its settings menu?
Oh, duh! Sorry, I mis-read the question.
2007-01-12 02:30 PM
PivoArch wrote:I think it's possible....but need to modify the object though.TomWaltz wrote:Yes you can, but then is actually shows up on all stories. Even if the wall does not.
2007-01-12 03:16 PM
2007-01-12 04:35 PM
2007-01-16 03:11 PM
