Exists in plotmaker but not in the plan!!!
Hi
I've got a plotmaker file that has an ellipse drawn in the middle of an area. This doesn't exist in the plan file!!!!
Both plan file and plotmaker file have been recreated and all layers switched on in the plan to see if it was hidden.
Anyone got any ideas as to where this rogue line could be from?
cheers
Adri
1 Reply 1
Adri
Sometimes when you rotated, mirrored or otherwise eddited an arc (in AC9 I assume?) it would display 180degrees from where it should be. Maybe the same has happened for your ellipse. Check in your PM layout if there is an arc/ellipse missing from elsewhere in your drawing. It will still look to be in the right place in your PLN model. If so, redrawing it is the best fix AFAIR.
HTH
