‎2010-09-28
01:12 PM
‎2023-05-26
03:22 PM
Rubia Torres
‎2010-09-29 05:52 AM
‎2010-09-29 08:49 AM
‎2010-09-29 09:55 AM
‎2010-09-29 11:34 PM
‎2010-09-30 04:13 AM
‎2010-09-30 05:21 AM
‎2010-09-30 05:26 AM
Nuge wrote:...and the old becomes new again. The simplicity of using PMKs has always been a great fallback position in a pinch. I'm so glad they brought them back. Automatic functions are great when they work (and if they save more time than they require to set up) but sometimes the old manual approach is best.
I halved my file size by moving the layouts to a separate file (and gained some performance), I use PMK files generated in the "model" file then update them in the "layout file" this is quick and "painless" and simple to update and eliminates the need to update in a separate archicad for any layouts as this take some time with large files.
You just publish to PMK files in a folder structure then place them onto a layout (separate file), set to update automatically re-publish any changes and they will automatically update on the layout
You can also have a revision history of drawings stored as separate pmk files.
Sections/Elevations/Interior Elevations/3D Documents seem to take a large slice of the file size so any thing you can reduce if seperate the better
‎2010-09-30 10:33 AM
Matthew wrote:
Are you having performance issues? I find ArchiCAD is generally pretty good about handling large files without a lot of waiting. Of course this is less so with teamwork and depends on the network as well.
‎2010-09-30 10:52 AM
Nuge wrote:
. . . , I use PMK files generated in the "model" file then update them in the "layout file". . .
