Fill translation problems
Hello I'm having troubles making new fills after upgrading to Archicad 18. In archicad 17 my firm made a standard fill for each building material. like concrete is squares in an angle and so on... but when io draw them as a new fill they show a solid fill don't understand why. I have made custom fills myself and everything looks as it should in element attributes. hope someone can help
TNX
Kevin
3 Replies 3
Check that you don't have an override set in either Model View Options or Renovation Filters which could alter the display of fills.
if i copy a fill into my template it desplays normally
weird that it despays a fill that is copied when there was an override on in model view options
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/views-of-the-virtual-buildin...
if someone else had has this problem
Thanks
