Fills, fills and fills.
Hi again!
Looked through the forum to see if it is true that you can not specify the orientation of a fill in a section besides in the attribute settings? Like you can align a 3d texture?
Could not find anything.
Anyone knows!?
Also; impossible to create fill using dotted lines? (snift)
I work in 9 (still :-/)
2 Replies 2
Link
Align 3D texture aligns the fill and the material, since the are basically one in the same. In AC9 however, this command doesn't work so well with roofs in AC9. You'll need to really look more perpendicular to the roof plane to get it to work. It's a little finnicky, much better in AC10 IMHO.
Link.
Hi Link,
Thanks.
Will hand in final project in 3 weeks, and then a: start breathing again and b: start working in 10 (if anyone in DK gets in the game)
Have a nice weekend 🙂
